2001 Camaro ss starts then dies bypassed vats still no go what else? BCM?
Old 05-28-2015, 07:00 PM
Haddixj's Avatar
Default 2001 Camaro ss starts then dies bypassed vats still no go what else? BCM?
The car ran fine up until one time it wouldn't start and run anymore. Did a search read could be vats so found the sticky put 3 resistors in series to equal the proper amount tried it and no luck. It will start like it is hitting of the fuel pump prime but after that will not stay running, if you use starting fluid it will run for a while and sound normal I was told.
I just sold the car after having it for 2 years and the guy made it home and then tried to fire it up and then this begun. Is there anything else to check?
The security light is on with the key in the on position and goes off while cranking. I have disconnected the battery, cleaned the MAF, and checked what connectors I can reach.
Is there anything else I am missing? could the crank position sensor be causing it?
Old 05-28-2015, 07:23 PM
OSU Football Fan's Avatar
I had to do the VATS bypass a couple of weeks ago. If the security light turns off once the car is started, that shouldn't be your problem.
Has the car thrown any codes from the check engine light or service engine soon light? When you turn the key to the on position, do you hear the fuel pump prime? Have you ever changed the fuel filter?
Old 05-28-2015, 09:19 PM
Haddixj's Avatar
just heard from the dude, it only had 10lbs of fuel pressure after it primed and then shut off so it looks like the fuel pump is toast
Anyone expierence something like this? From a brief search I didn't turn anything up
Old 08-18-2015, 08:19 AM
Haddixj's Avatar
following up
pulled the tank and the rubber fuel hose in the pump module split causing the problem
Quick Reply: 2001 Camaro ss starts then dies bypassed vats still no go what else? BCM?
