uh oh look what i found!
Old 06-13-2004, 06:42 PM
MadMike's Avatar
Default uh oh look what i found!
Hey guys, I was changing the oil in my Z today when i found this attached to my drain plug . It looks like a needle bearing , but my question to you is from where? possibly a rocker arm? , Keep in mind i work at a garage and it is possible that one of the funnels i was using had it stuck in there and it slipped in when i poured oil down the funnel. and also i do not hear any funny noises, or get any weird response when i do this , if any of you could help it would be appreciated. Thanks alot guys -- Mike
IF the image doesnt work could someone please let me know, it shows up on my screen But i dont know if it actually works for you guys.
uGH, if the link doesnt work just go here you can see all the pics, i took off the drivers side valve cover and snapped some pics of the rockers but i dont think i got the right side. http://community.webshots.com/album/152326386lUMPXq
Old 06-13-2004, 07:47 PM
KimberWS6's Avatar
No pic doesn't work.................needle bearing ,like maybe from a rocker arm?
Old 06-13-2004, 08:51 PM
Moderator
jimmyblue's Avatar
Yes, it looks like a roller bearing and there is a GM TSB
out on this problem. Whether you can get warranty
satisfaction at this point, I don't know, but it is a
manufacturing defect based problem so I'd go for it.
That, and one of more of your rockers is probably
well and truly screwed.
Old 06-13-2004, 08:57 PM
MadMike's Avatar
Hey, thanks Jimmy, Upon removing the valve covers, how might i be able to tell which one is screwed, will it be totally obvious? i have the drivers side off, as you can see , i tried to take closeups of the rockers but im not sure what im looking for as far as the rocker falling apart.
