Horsepower upgrade
Horsepower upgrade
Got a 6.0 out of a 2008 trailblazer ss. Doing an ls swap into 73 Impala. What are some inexpensive hp upgrades I can do with putting a dent in bank acct. trying to reach at least 500 hp
Restricted User
Modern wet kits are far safer and more practical.
The hardest part is refilling the bottle.
I've ran nitrous on 2 different cars over the last 10 years. These were just street cars, and when setup right it's no more dangerous than a blower or turbo. If you don't need the extra power all the time then nitrous simply can't be beat for the money
Spraying threw shifts on cars that were not made for extra power ect.
I think to many non car people that love fast and furious movies just throw it on not knowing that higher octane is your friend and has a slower burn rate, not faster burn rate like movies and gas station additives would have you believing.
When talking about a setup I would like to do to random non car people I tell them I'm going to run a stand alone tank to pull fuel off when I spray and that I'm going to run 120+ octane in that tank and there like OMG, YOUR GOING TO BLOW YOUR MOTOR, LOL......oki doki, thanks for the heads up.
I agree, I also think nitrous kinda gets a bad wrap because of people just buying the bare minimum/basics needed and putting the nozzle where ever they see fit, without knowing anything about jetting, continuing to run 87 octane (depending on what they are putting it in) , spraying to big of shot on a 4cyl motor that barely makes enough power to get out of its own way in the first place.
the biggest reason people blow their **** up with nitrous is because they do not do all the research and get tempted by seeing the $500 price tag of a "complete" wet kit vs the $5000 tag of a supercharger. They don't do the full supporting mods and don't understand their system and eventually it all falls apart.
I have to agree nitrous isn't that bad if tuned right and a little personal knowledge wont hurt too. I used to even after a good tune would read my plug to make sure everything is burning good on the cylinders. the only problem I had well not really a problem is after a while I would notice that my car didn't feel as tight. May have been all in my mine though but I like a tight driving and feeling car.
That engine will have 243/799 heads, you can have the ports cnc machined, fittedfor larger valves ans heavier springs get a good cam from SDChevrolet, that should be close to 500 with a little intake rework and injector up grade... Head work is about 1000$ at Patriot or a similar place.
