What's the difference...?
Old 07-06-2004, 01:43 AM
LS1 Brent's Avatar
Default What's the difference...?
Between a short block and long block?
Old 07-06-2004, 01:49 AM
Just Floor It's Avatar
A shortblock pretty much includes the block and the rotating assymbley(Crank, Pistons, Rods) Maybe a couple other things...
A long block includes the cam, heads, and the shortblock...
Hope this helps
Old 07-06-2004, 01:57 AM
Check this out from Cartek:
CARTEK 347 CID LS1 SHORT BLOCK
Cartek custom heat treated crankshaft
Scat 4340 forged I beam connecting rods
JE custom nitrous / boost pistons
Childs and Albert plasma moly ring set
Clevite P series bearings
Rotating assembly fully balanced
Engine blueprinted
Cartek hyd. roller cam
Double roller adjustable timing chain
Fully assembled short block (Engine core required)
$4,250.00
Cartek 347 CID LS1 LONG BLOCK
Engine blueprinted
Cartek stage 2 LS1 heads
Fully assembled long block (engine block and head core required)
$6,750.00
Old 07-06-2004, 06:39 AM
jrp
SN95 Director
jrp's Avatar
a short block is a block with a rotating assembly (crank, rods, pistons, rings, bearings) and a long block is a shortblock with heads.
cam, lifters, ect are all options you can add when buying a long/short block but they dont come standard.
