Installing clutch?
Installing clutch?
I need instructions, preferably w/ illustrations, on how to install a spec stage III clutch on an 01 camaro ss. I already went to SPEC's website and they had nothing and wont return my e-mails.
but i could tell you right now you will need a new slave probably new master and i think a bigger line to handle the extra hydrolic preasure.
Originally Posted by Z28Venom
Nah... He has an '01. slave and master are good to go..
But you will need ALOT of extensions to get the bolts at the top of the bellhousing.
Basic rundown of my install....
-Drain tranny ( less weight )
-Remove driveshaft
-Remove entire shifter
-Tranny jack
-Bellhousing Bolts
-Tranny Crossmember
-Remove tranny
The installation of the clutch is pretty straight forward. Getting it back together is just the reverse..
I believe there is a more indepth writeup at www.ls1howto.com
-Remove driveshaft
-Tranny jack
-Bellhousing Bolts
-Tranny Crossmember
-Remove tranny
