I have a serious prob.. HELP!!
Here is the deal.. I guess it's not to bad..... I have a 99 SS.. OK when I get on it and shift hard into second or third it sounds like the rearend or drive shaft hits the floor or something??? So I jack my car up and look and my drive shaft has dents in it around in one spot.. It is about where the Ebrakes mount underneeth.... Anyone know what is cousing this??? Shocks??? This is my first camaro and I love it just trying to fix this prob.. THANKS!!
That's what she said...
and remember, you usually have to take the trans mount OFF to check the mount. it could look perfectly fine and be torn to hell (like mine )
4 crossmember bolts (15mm), and one 18mm deepsocket for the mount itself and the crossmember comes out. make sure to have the trans supported when doing this or you will have a mouthfull-o-t56
from there its just 2 bolts to remove the mount from the tranny.
Copy & Paste Moderator
Originally Posted by enisguy
Moving this to the newbie section...
Back on topic:
My guess would be tranny mount or torque arm. Also, if the drive shaft is dented, it may now be out of balance or bent enough to cause vibrations.
