simple mods?
simple mods?
I'm away at school and bored, looking for some sort of easy mod to do to my 98 formula. Keep in mind I only have basic tools such as a ratchet set.
What kinda things can you come up with that I could do.
btw, I've already done a lid and cold air intake
Lid, bellows (not necessarily something you should do), throttle body (have it ported), thermostat, shifter if you have an m6
appearance mods: (halo's, whistlermodded), corners, grille
if you have access to a jack at all, you could do lower control arms, but the above mods are all pretty much easy w/ your basic tools
If you still have the egr hooked up you can cut off the end
of the egr tube that sticks through the TB.
every little bit helps an all you need is a screwdriver an a hack saw
