how much slower is an automatic ls1 than a manual ls1?
Old 01-23-2006, 09:01 PM
GXPPOWER's Avatar
Default how much slower is an automatic ls1 than a manual ls1?
what do the ls1 auto's run in the 1/4 average? mainly the Ram air TA's i have a GXP but this is a car that i would like to keep in semi good shape. and im not getting younger and a TA ram air package has always been my dream car. but i dont like manuals so im curious how much slower the autos are.
Old 01-23-2006, 09:11 PM
jrp
SN95 Director
jrp's Avatar
bone stock, mid 13's. same as an average m6 driver. the t56 traps higher though. when modded an stalled the 4l60e will usually out et. a t56 all things being equal due to better consistancy.
all that being said...........
t56 > 4l60e
Old 01-23-2006, 09:13 PM
camaroextra's Avatar
my automatic: 13.272 @106 2.106 trap speed stock (cept for lid) 2002 z28 with 38k on dayton 245's (pos) oh yeah stock 3.23 option
cant say for other cars but i can say for mine
Old 01-24-2006, 12:32 AM
Tech Resident
WhiteKnightZ28's Avatar
Check the sticker on the door...
Code GU5= 3.23's
Code GU2= 2.73's
I've got the 3.23s and can put a few cars on my buddys 2.73 car.
Old 01-24-2006, 08:01 AM
300bhp/ton's Avatar
manuals should be more fun and you'd have a lot more control over the car, as you really can't engine brake very easily with an auto. So on a road course (or just twisty roads like in the mountains) and on a circuit a manual would be a decent amount faster. Espcially as you'lll probably cook the brakes with an auto a lot easier.
That said and done, the auto boxes work very well in the Fbody's and do perform well on the road. To really see the advantage of a manual car on a twisty road you'd have to drive like a total lune and well beyond what is reasonably acceptable for performance road driving.
At the drag strip the M6 cars should be quicker because they lose less power thru the drivetrain (more rwhp) and the internal gearing is better as is the final drive ratio. High 12's @ 109mph are possible, although low 13's @ 107mph are more common. An A4 will do mid to mid/high 13's more often at 102-104mph depending on which final drive ratio.
However, all you need to do is add a good stall, some 3.73 gears and some sticky tyres and chances are you'll beat more M6 cars than those that you lose too with like for like mods.
If you're not happy going for a M6 get a A4 - you won't be dissapointed
Old 01-24-2006, 08:22 AM
jrivera04's Avatar
IMHO a M6 will always be more fun to drive just for the fact that you can control the gearing. But with that said, my A4 is awesome to drive. If you put a stall in an A4 they are pretty hard to beat as far as consistency is concerned. I noticed a difference just by increasing the shift firmness and moving the shift points higher on my stock stall. But I plan on getting a 3500 stall put in.
Here is another thing A4's don't have to worry about as much while doing the 1/4. Valve float and 10 bolts rear ends. If you miss a shift in a M6 you can float the valvetrain and do some damage. Also, a M6 can break a rear end while stock just by putting some drag radials and hooking up good. A4's can just preload and launch with little chance of breaking the rear.
Just some food for thought.
Old 01-24-2006, 04:50 PM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,794 Likes on 1,278 Posts
LS1Tech 20 Year Member
jrp is right on the money. There is very little difference at all between the M6 and the A4 LS1 F-bodies stock for stock at the drag strip. A few years back when I used to be at the track more often, the norm for all us LS1 guys (when stock) was usually mid-low 13s whether is was an M6 or A4. The fastest stock car in our group was an A4 '02 WS6 running 12.9x's @108. Granted, that is not the norm for either the M6 or the A4 stock, but I have seen it happen.
Out of the 10-12 of us that used to hit the track together (most were M6 cars), there weren't any M6s that were significantly quicker mod for mod (or stock for stock) than the A4 cars.
Bascially, stock for stock, figure that the 1/4 mile ET will be nearly the same, with 1-2mph higher traps for the M6 assuming the M6 driver is average/good. If the M6 driver is excellent, then it might run a couple tenths quicker than the A4 car.
Old 01-24-2006, 04:52 PM
RPM WS6's Avatar
FYI, I'm just like you. I have no interest in manual transmissions. Don't worry about the guys telling you that the M6 is more fun. If you don't like shifting, than the M6 will be nothing but a pain. It's only more fun if you actually want it. For those of us that like autos, the auto will always be more fun.
Old 01-24-2006, 07:29 PM
DrewSG's Avatar
Do M6's have a higher top end than a A4 since they have more gears?
Old 01-24-2006, 07:40 PM
no the gears run out of engine before the engine runs out of gears.
both a4 and m6 are limited by the power of the engine, not the gearing
Old 01-24-2006, 07:53 PM
LS1Tech Sponsor
Superman09's Avatar
Yea from what ive heard, at the track, the A4s are quicker and the M6's are faster. Ive only been to the track once and light bolt on auto was running 13.2@107, there was one other f-bod ls1 there, a vert ss M6 and he didnt break 14 all day. Its all i nthe driver. With a good driver m6 stock vs a4 stock ,you will see close to same results i believe, stalled the A4 will be quicker but the m6 still faster. For the street M6>A4, for the track, A4>M6
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 01-24-2006, 09:06 PM
GXPPOWER's Avatar
Default hey thanks
thanks guys really helpfull. ok just curious which a4 gear ration version am i looking for.. since their are 2?
Old 01-24-2006, 09:16 PM
jrp
SN95 Director
jrp's Avatar
look for the RPO, that will tell you which gear set you have.
Old 01-24-2006, 09:21 PM
02 Camaro SS's Avatar
If you don't like manuals, get an automatic and put in a torque converter. Then that would would be faster than just about any M6 with equal mods. From what I've seen, most stock A4's run 13.6-13.9@102-104mph and most stock M6's with good/decent driving run 13.2-13.6@104-107 mph. You want to get the 3.23 gear ratio which is the GU5 RPO code like WhiteKnightZ28 said.
Old 01-24-2006, 11:54 PM
Humvee z28's Avatar
i would add some insiteful knowledge, but most covered it al. there are pros and cons to both drivetrains. get what u want and not what others tell u to get. remember U are the one paying the monthly payments and driving the car everyday.
Old 01-25-2006, 12:53 AM
BriancWS6's Avatar
Well I have had both. A 01 WS6 a4 and now a 02 WS6 m6. I consider myself to be a well above average driver, I ran 12's with a lid on street tires the first time to the track with my car.....could have gotten even lower with more seat time.
Anyway I am positive that an equally running engine (meaning both cars were putting out the same or as close to the same power as possible, no freaks, no turds) that with a great driver in both that the m6 would prevail with them both being stock....I have had two strong running LS1 cars so this is not just BS talk either.
A stalled auto is diff, but stock for stock all the m6 needs to stay ahead indefinately is a great driver to get all it's potential to the ground...that's my opinion.
Old 01-25-2006, 01:20 AM
Pimpium57's Avatar
Even being a good driver, I recently sold my M6 car for a stalled A4 and love it. If you don't like manuals, then don't question it......grab an auto, throw in a stall/shift kit/trans cooler, and don't look back (at the M6 guy trying to play catch-up in the rearview mirror ). Just playin'.....
Old 01-25-2006, 03:19 AM
Commando's Avatar
well, for me i've always driven a manual cars and it's really a PITA if u drive daily, for me i find the autos much more fun and i can't wait to get an auto.. it's about what u like..i'd go with an auto and when speaking about an f-body,, they are too damn fast to think about a fraction of a second..
Old 01-25-2006, 05:51 AM
kyle91z28's Avatar
hey io'm drunk as hell right nwo but, if uwant t roll race, DO Not but an auito. Autos have too mayn dead spots plus they are boring. If you get a stall it wilk sound like ur flooring it everywhere when ur not and u'll still be nust a boring auto. Get a mnaul. a sports cars is not a sports car without a manual REMEMBER THA.
Old 01-25-2006, 06:07 AM
minesfaster's Avatar
I am kinda buzzing aswell kyle LOL i had a 1994 formula a4 and those 4l60e tranny are garbage. I switched to a 2000 z28 m6 and i like it much better.
goodluck.
Quick Reply: how much slower is an automatic ls1 than a manual ls1?
