help deciphering door stickers
Hey guys,
im looking to buy a 02 camaro SS, and it really seems like many people dont have any clue what THEY are selling anymore. I found a car i am halfway interested in even though its not what i was looking for, and everyone says to look at the door stickers to make sure everything is alright but the car is abotu 589 miles away so its not a short drive, i had them email me pics of them so if anyone could please decipher the stcikers and tell me what they say i will be greatly apreciative
http://home.earthlink.net/~loyaltrek...ticker%231.jpg
http://home.earthlink.net/~loyaltrek...%20sticker.jpg
thanks guys
thanks guys
Last edited by ACW; 04-05-2006 at 01:50 AM. Reason: changing large images to links
Plug the RPO codes into www.lonestarthunder.com This car looks like a '01 A4 Z28 with 2.73 gears - recognize some of the same codes my car has.
This car has 2 options that the majority of f-bodies do not have but I would not consider them "rare" either. The first is that this car is a hard top. The majority of f-bodies in 02 were t-top cars. The other option is the Y3F option which is the "Sport Appearance Package". This means this car should have the lower ground effects and the additional 3 piece add ons to the standard Z28 sploiler. Other than those 2 it appears to be a pretty standard 02 Z28. This was a very early 02 given the 6/01 build date. Other options are the NW9 which is Traction control, AG1 is power drivers seat, AU0 is remote keyless entry, A31 power windows, QFZ are the Z rated tires, G80 is the posi rear, GU2 is the 2.73 gears and MX0 is the code for Automatic trans with O/D.
Also like stated above, be careful since there's paint over the stickers... might mean the car was in an accident and had to be repainted... or it might just mean the owner painted it a different color. Who knows? Run a Carfax, but that doesn't catch absolutely everything... it should tell you what you need to know, but also try and make visual inspections for signs of past repairs, that kind of thing.
Is this car being sold by a dealer or a private party?
Here is a listing of RPO Codes for the 93-02 F-Body
A31 power windows
AAA factory tint
AC3 power 6 way, bucket, driver
AG1 Adjuster, 6-Way Power, Driver Seat
AG4 Adjuster, 2-Way Manual, Driver Seat
AR9 front bucket, european style, passenger & driver
AH3 Adjuster, 4-Way Manual, Driver Seat
AK5 Restraint System Front Seat, Inflatable, Driver and Passenger
AN4 Restraint Provisions, Child
AQ9 Seat, Passenger and Driver, Recline
AUO Lock Control, Remote Entry
AUD remote keyless entry
AU3 Lock, Side Door, Electric
A31 Window, Power Operated, Side
A90 Lock, Rear Compartment Lid, Remote Control, Electric
B35 Floor Mats, Rear, Carpeted Insert
B84 Exterior Molding, Body Side
CC1 Roof Hatch, Removable Glass Panels
C41 HVAC System, Heater
C49 Defogger, Rear Window Electric
C60 HVAC System, Air Conditioner, Manual Control
DD9 Mirror, Outside, LH & RH, Remote Control, Electric, Breakaway, Painted
DE4 Sunshade, Removable Hatch Roof
DG7 Mirror, Outside LH & RH, Remote Control, Electric, Painted
DL5 Decal Roadside Service Information
D35 Mirror, Outside LH Remote, RH Manual, Painted
D5X gear-driven speedometer
D81 "GT" raised spoiler
D82 Paint Special
FE2 Suspension system, Ride handling
FE9 Certification Emission, Federal
F41 Suspension System, Firm Ride Handling, Front and Rear
GU2 Axle, Rear 2.73 Ratio
GU3 auto tranny,
GU4 Axle, Rear 3.08 Ratio
GU5 Axle, Rear 3.23 Ratio
GU6 Axle, Rear 3.42 Ratio
G80 Axle, Rear Posi-traction (Limited Slip)
G92 performance suspension package
ILD Trim, Interior Design
IL2 Trim, Interior Design
IPB Trim, Interior Design
IP2 Seat, Leather Sport Front Bucket, Driver & Passenger, Reclining
J41 Brake System, Power, Front Disc, Rear Drum, Cast Iron
J65 Brake System, Power, Front and Rear Disc
KC4 cooling system, engine oil
KG9 Generator, 140 Amp
K05 Heater, Engine Block
K34 Cruise Control, Automatic Electronic
K68 Generator, 1 05 Amp
LT1 Engine, 5.7L (V8) MFI
LS1 Engine, 5.7L (V8) MFI
L36 Engine, 3.8L (V6) MFI
MD8 THM 700 R4 auto tranny
MM5 Transmission, 5-Speed Manual (Merchandising Option)
MM6 Transmission, Manual, 6-Speed, Borg Warner, 65mm, 2.66 1st, 0.50 6th, O/D
MN6 Transmission - 6-Speed Manual (merchandising Option)
MXO Transmission - Automatic O/D (Merchandising Option)
M30 Transmission - Automatic, 4-Speed, 4LE, Electronic
M49 Transmission, Manual, 5-Speed, Borg Warner, 77mm, 3.75 1st, 0.76 5th, O/D
NA5 emission, federal, tier 0
NB6 Emission System, California Requirements, Tier 1
NC3 Tailpipe Modifications
NF2 Emission System- Federal Requirement, Tier 1
NK3 Steering Wheel, Sport, Soft Rim, Simulated Leather
NP5 Steering Wheel, Leather Wrapped
NW9 ASR Traction Control
N36 Steering Wheel, 4-Spokes, Sport
N60 Wheel, Aluminum, Painted
N92 Cover, Wheel, Bolt-On
N96 Wheel, 16x8, Cast Aluminum
N98 Wheel, Chrome, Var 2
P05 Wheel, Chrome, Var 1
P08 Cover, Wheel, Super Deluxe
PW7 16 x 8 alloy wheels
QA7 Wheel, 16x7.5, Aluminum
QB3 Wheel, 16x7.5, Steel
QEA Tire, P215/6OR16 BW R/Pe ST TL AL2 94T
QFZ Tire, P24515OZR16 BW R/PE ST TL AL3
QII Tire, P21516OR16 BW R/PE ST TL AL3 94H
QLC Tire, P24515OZR161N BL R/PE ST TL HW4
STE Plant Code-St. Therese, PQ, GM of Canada
TR7 Headlamps, Automatic Control Leveling System
T39 Lamp Turn Signal, Auxiliary
T43 Spoiler, Rear
T61 Lighting- Daytime Running
T96 Lamp, Fog
UA6 Theft Deterrent System
UB3 Instrument Cluster, Oil, Coolant, Temperature, Volts, Trip Odometer, Tachometer
UK2 Lever, Directional Signal, Multifunction
UK3 Electronic System Accessory Control
UL0 AM/FM Cassette ETR 200 Watt Monsoon Sound System w/cassette
UN0 AM/FM Cassette ETR 200 Watt Monsoon Sound System w/CD player
UN6 Radio, AM/FM stereo, Seek/Scan, Auto Reverse Music Search Cassette, Clock, ETR
UQ0 Speaker System 4, Dual Front Door Mounted, Standard Range Quarter/Shelf
UU8 Radio, AM/FM Stereo, Seek/Scan, Auto Reverse Music Search Cassette, HPS, Clock, ETR
U1A CD radio, 10 speaker
U1C Radio, AM/FM Stereo, Seek/scan, Compact Disc, Clock, ETR
U1S 12 Disc Compact Disc Changer
U1T Radio, AM/FM Stereo, Seek/Scan, Compact Disc, HPS, Clock, ETR
U18 Speedometer Instrument Kilometers
U19 Speedometer Instrument, Kilometers and Miles, Kilometer Odometer
U62 Speaker system 4, Dual Coax Front, Dual Coaxial Package shelf
U65 Speaker system 5, Dual Front Door Mtd, Dual Ext. Range Panel, Single Rear Compartment
U73 Antenna, Fixed
U75 Antenna, Power
UT6 AM/FM stereo, seek/scan, auto rev
UW2 speaker system, 10, quad front door mounted, dual rear sail panel
V73 vehicle statement, US/CANADA
VG8 Label, Vehicle, Notice to Buyer
VH5 Plate, Vehicle Information
VK3 License Plate, Front Mount Package
VM3 label information consumer, contains bumper impact standared
VP6 Noise Control
WS6 Performance Package - Formula/Trans Am
WS9 model conversion, FORMULA
WU8 SS Performance Package/Appearance Package - Camaro
W51 Entertainment system - Radio, AM/FM-stereo, seek/scan, cassette, 4 Speaker system · Standard Range
W52 Entertainment System - Radio, AM/FM stereo, Cassette, Equalizer, 4 Speaker system - Coaxial
W53 Entertainment System - Radio, AM/FM Stereo, Compact Disc, Equalizer 4 Speaker System - Coaxial
W54 Entertainment System - Radio, AM/FM Stereo, Cassette, Equalizer, 10 Speaker System, Amplifier
W55 Entertainment System - Radio, AM/FM Stereo, Compact Disc, Equalizer 10 Speaker System, Amplifier
W57 Entertainment system - Radio, AM/FM stereo, Cassette, Equalizer, 4 Speaker system - Coaxial
W58 Entertainment system - Radio, AM/FM Stereo, Compact Disc, Equalizer, 4 Speaker system - Coaxial
W59 Entertainment system - Radio, AM/FM Stereo, Cassette, Equalizer, 6 Speaker System, Dual Front Door Tweeters/Woofers, Extended Range Shelf
W66 Merchandised Package - Formula
W73 Entertainment system - Radio, AM/FM Stereo, Compact Disc, Equalizer, 6 Speaker system, Dual Front Door Tweeters/Woofers, Extended Range Shelf
Y81 Merchandised Package - Firebird
Y82 Merchandised Package - Trans Am, Base Coupe
Y83 Trans Am model
Y84 Merchandised Package - Trans Am
Y87 Merchandised Package - Performance Enhancement
Z28 Merchandised Package - Special Performance
Z49 Canadian Modifications
01U Primary Color exterior, Special
05Q Molding Color, Cyclamen
O5U Primary Color Exterior, Cyclamen
1LE Performance Package Components
101 Interior Trim - Arctic White
1OT Top Color - Arctic White
102 Trim Combination Leather, Arctic White
1OQ Molding Color - Arctic White
1OU Primary Color - Exterior, Arctic White
12B Trim Combination - Cloth, Graphite
12D Trim Combination - Cloth, Graphite
121 Interior Trim - Graphite
14B Trim Combination - Cloth, Dark Gray
1SG Preferred Equipment Group
28U Primary Color - Exterior, Navy Blue Metallic
1SA option package 01
1SC package option 03
1SZ discount option package
37Q exterior molding color, manta green metallic
17P wheel color, silver mist metallic
37U primary color, exterior, memphis blue metallic
141 trim/leather combo
17P wheel color; silver
8TH rear springs
9TH rear springs
81Q molding color, bright red
81U exterior color, bright red
A31 power windows
AAA factory tint
D82 Paint Special
GU3 auto tranny,
T43 Spoiler, Rear
T96 Lamp, Fog
U73 Antenna, Fixed
U75 Antenna, Power
VP6 Noise Control
Y83 Trans Am model
8TH rear springs
9TH rear springs
All Camaro SS cars have the "WU8" RPO code, as shown above. Any SS with additional SLP options added on also (i.e. chrome wheels, Auburn differential, etc.) had the "Y2Y" RPO code also. (I think that's what it was. It's been a long time since I've delved into this) Remember, you can also call SLP with that VIN and they can tell you if it was an SS, too.
