Ticking noise on low RPMs ?!
Old 06-13-2006, 07:08 AM
kaell's Avatar
Default Ticking noise on low RPMs ?!
I have a ticking noise when a press WOT on 4th, 5th and 6th gear under 1000rpms, when under heavy pressure.
Anyone understands what I mean?
No ticking noise above 1600-1700rpm when the engine starts pulling up to redline...
Is this any problem, or should a pushrod-engine sound like this?
Old 06-13-2006, 02:37 PM
'Trust''s Avatar
You mean like when the car is moving slow for the gear so flooring it doesnt really do much? I.E. flooring it from 40 MPH in 6th gear? Is the ticking noise definately coming from the motor? In threads like this its required that you specify what car, mods etc. to help
Old 06-13-2006, 03:41 PM
kaell's Avatar
Yepp, flooring it on high gears at low speed i.e. 40mph in 6th gear, or more likely 15-25mph in 4th or 5th.
It's like a ticking noise when the motor is under heavy pressure.
Camaro LS1 1999, heard it easier when it was stock, but now I have exhaust and it's a bit louder.
Old 06-13-2006, 04:38 PM
staringback05's Avatar
u sure its a ticking or a thumping?...if its a engine problem it could be anything from valves to bearings....can you tell on the engine where the noise is coming from?
Old 06-13-2006, 04:40 PM
'Trust''s Avatar
If its louder now with exhaust then its most likely bent pushrod, lifter giving out or something similar, you may just be low on oil though!
Old 06-13-2006, 06:17 PM
kaell's Avatar
No, no, no... I have plenty of oil, recently changed. I doesn't hear the noise as clearly now as when I did when running stock (more quiter)
I don't see it as a problem, the noise appears when the engine starts to choke, only when it doesn't have the strength enought to pull on that high gear.
I don't think it's a problem, because I was as fast (stock) as a stock SS.
This is my first pushrod-car, so I'm most likely curious how It's SHOULD be sounding.
Old 06-13-2006, 06:59 PM
hmm im lost now
Old 06-13-2006, 09:24 PM
Tech Resident
ChocoTaco369's Avatar
i think i know what you're talking about. it's kind of like a chattering, like hitting two small sticks together very quickly. it would always do that on my old 3.4L V6 bird when i just locked up in OD and gave it enough gas to accelerate to the MAXIMUM WITHOUT unlocking. i just always figured it was the pushrods going back and forth really quickly since your engine is pulling hard in such an unnecessarily high year. i'd say it's the rods, completely normal. i'm sure my LS1 does it too, i'll have to try tomorrow.
btw my 3.4L did that from the day i got it @52k miles. it ran great for 30,000 more til i traded it in. i'd say you're listening for anything that can worry you for no reason.
Old 06-13-2006, 09:29 PM
LS1Aggie09's Avatar
i kind of have a tapping noise as well on first startups of each run and even all the time sometimes at RPM's of idle up to 1700...i just always thought it was normal but it seems a little louder now than two weeks ago so idk...
Old 06-13-2006, 09:44 PM
kruthes1's Avatar
maybe lifters? Aren't these cars known for having a little lifter noise at idle? I know mine does.
Old 06-14-2006, 07:13 AM
kaell's Avatar
ChocoTaco369: You got it...
I think (hope too) it's pretty normal.
Old 06-14-2006, 07:34 AM
Justin01SS's Avatar
I had a sound similar to that a while ago when u stab it in a high gear, almost like bolts hitting a pan. definatly was pinging due to bad gas or lower than required octane.
Old 06-14-2006, 11:34 AM
Shirley Temple Drinker
Sgt. Spuds's Avatar
Prolly a small exhaust leak.
Old 06-14-2006, 11:43 AM
heymoej's Avatar
maybe you just have real good ears??? ha!!! i just put comp cams 1.85 rockers & my valve trane is much louder than stock!!!!!any chance another owner could have done this???
Old 06-14-2006, 11:51 AM
warpwr's Avatar
You're lugging it and it is pinging or detonating in protest.
If you are cruising at 1000RPM in 6th say, drop down a few gears and then stomp on it. If it was an A4 it would kick down by itself for that very reason.
Old 06-14-2006, 12:36 PM
sdbrown84's Avatar
Regardless of what you do you will have some detonation and KR if you floor it in a high gear say 6th at 1K RPM. The ticking however usually comes from a bent pushrod or an exhaust leak. If you have block-off plates check to make sure your bolts are all secure.
You may want to double check your exhaust manifold, EGR, AIR, and make sure you all all bolted down to TQ spec. Then you will have to check internally for the notorious bent pushrod.
Old 06-14-2006, 11:53 PM
Tech Resident
yea i know what you mean. when you're completely out of the powerband it sounds like two metal sticks clanging together super fast, just muffled, but the second you get into even a little powerband it's gone. i think they're just the rods spinning extra hard since you're making it accelerate in such a low spot of power. i don't think it's anything to worry about in particular, but i suppose anything can happen. you may wanna try german castrol 0w-30 if you haven't already. it seems to quiet the LS1 down. maybe that'll help. i tried listening for that noise the other day but couldn't detect it, but i just switched over to german castrol 0w-30 on sunday so...
i just feel that if you listen hard enough to a car, you can, in your own mind if you're a little paranoid about your car (like i am), you can make up lots of situations where something sounds problematic. i say don't worry about it. treat your car right and if something eventually happens...well, you'd have to fix it anyway so it's a moot point.
Quick Reply: Ticking noise on low RPMs ?!
