Looking for help... Mod list here
hey everyone... I'm new to this kinda thing so have patience with me.. But neway.. I drive a 2001 automatic ws6. im looking to maybe make close to 450hp at the wheels on all motor. the car is mostly stock.. i have an SLP lid, air box, and smooth bellow. here is my mod list that i am planning on doing this winter..
QTP long tube headers
QTP off road y pipe w/ dual QTEC cutouts
SLP loud mouth II catback
Yank 3400 Nitrious converter
Spohn Adj. LCA'S w/ sepherical rodends
Spohn Full length adj. torque arm
Richmond 3.73 gear
BBK Intake Manifold
SLP high flow MAF sensor
LOOKING TO CAM IT ALSO!!. i want an agressive cam but one that isnt that noticable.. i have a nitrious kit but it has not been put on yet.. the car will be set up for 100 shot. i need opinions on whether or not i should run this set up or what set up i should run. thanks
Richmond 3.73 gear
BBK Intake Manifold
Originally Posted by transamfreak01
yeah i know i need to tune the car but i was tryin to go without heads and maybe gettin them later on.. how does that sound?
with the converter, what kind is good? a buddy of mine has a neon... its one bad machine... ne way, he has a 3500 but his car will not move until that 3500 mark is hit. but ive heard from other people that certain cars do not do that. this is going to be a street car and taken out on weekends.. i dont want anything disgustingly big.
That's what she said...
You aren't going to make 450rwhp with stock heads, no matter what's bolted to them or what cam is in it, especially with an auto. The only way to make that power on stock heads is if you've got a blower/turbo pumping air in.
Do a search on some existing setups and see what they're running. A set of small-bore 225cc AFR's and a big cam could get you there with a nice tune and full bolt-ons.
i was reading today on another forum and they were talking about an 01 ws6 hit low 11's on stock heads and i think it was an SS that hit high 10's on stock heads.... im looking for mid 11's on motor.. ill be happy with that.
Spending money on making your car dead hook and cut a 1.5x 60' will do a HELLUVA lot more for your ET's than a set of expensive heads. If you're looking for a ***** out highway roller with tons of break-neck power, then you can devote all your money to motor mods.
90% of the cars in my area who have the power to beat me can't put it to the pavement. Tires/suspension can win alot more races than 40 more HP.
Richmond 3.73 gear
BBK Intake Manifold
Richmond 3.73 gear
BBK Intake Manifold
List
1. cam
2. heads
3. 90/90
4. 3500 or better converter
5. SUBFRAME CONNECTORS (WELD IN)
6. your 3.73 gear
7.qtp exhaust
8.lca's etc.
9. tune
if your gonna do n2o check the n2o section
1. wet kit preferably
2. rpm window switch
3. full throttle switch
4. wideband controller (if you can afford it)
5. bottle heater
6. purge
i would say with that setup you would have to be 450 n/a at least and around 600 on a 150 shot good luck
7. remote bottle opener (optional)
i thought the 01 comes with the ls6????
hey blur.. what set up did SUX2BU have that ran an 11???? jus wondering... also how does my set up look with what i plan on doing?
This is what I mean when I was talking about ET's, they are relative. I'd much rather drive a cam'd car that runs 12.0 with a full interior, no weight reduction, on street tires with the a/c blasting, but some people want to go ***** out.
Other guys have gone 10.2's @ like 130mph with just a cam.
You've got a lot of figuring/reading/learning to do before you actually "do" anything, or you may not be happy with what you get in the end.
i would still like to run 11's without heads.... where should the money be put??? what brands should i go for??? money isnt really an issue yet i dont want to be a huge amount on this car right now
For suspension, check out BMR, for a convertor, check out fuddle or yank, and a cam, check out TSP, FMS and Thunder, just to name a few.
