160 thermostat...
Old 09-17-2006, 11:55 AM
tonic's Avatar
Default 160 thermostat...
Do you have to pay $45-$50 to get a thermostat or does a regular 160 degree thermostat work? Thank you,
Old 09-17-2006, 12:09 PM
Tainted's Avatar
you need it to be ls1 specific, but the 160* thermo isnt exactly gonna help your performance any. these engies are designed to be warm
Old 09-17-2006, 01:31 PM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,493 Likes on 1,075 Posts
I would skip that mod for an LS1.
Stick with the stock t-stat (which is a 186*F unit) and set the fans to keep coolant temps cycling in the 195-205 range. That's always worked best for me.
Old 09-17-2006, 02:21 PM
AFRLS1's Avatar
160* is what I have. works well
Old 09-17-2006, 04:34 PM
Z 2 8's Avatar
I put a 160 thermostat in my LT1. About a year later it died...Sure, it helps the car stay pretty cool, but in my experience they are cheap. (I had a hypertech) Someone else told me they had the same one and a year later it died, except he ended up blowing a head gasket.
When your car starts to over heat, it could be so many things. Your better off sticking with the stock one and getting a tune. This way, your fans kick on sooner and keep the car cool. As far as price, i think they are like $20.
Old 09-17-2006, 04:42 PM
98camaroLS1M6's Avatar
If you do put a 160 in you will definitely have to adjust your fans or your car will still run hot with stock fan settings.
Old 09-17-2006, 04:44 PM
WS6 Rampage's Avatar
Location: The dirty taint of the country. ...Los Angeles
I dunno..........It may not seem to be all that importand but I think it all adds up in the end,.....dont you?
I say swap it!
Old 09-17-2006, 05:12 PM
Tainted's Avatar
i really really wouldnt **** with the t-stat a few people can agree with me the stock one ifs mroe than adequet, all you need a a tune to ahve them cut on earlier. the car running to cold can make sludge and **** build up, not exactly a positive effect from a so called "performance" mod
Old 09-19-2006, 08:35 PM
Kurt D's Avatar
I disagree, sludge is going to build up from oil burning, not being too cool. Plus I really don't think the thermo will have much effect on engine oil temps anyway. The primary purpose (back in the day anyway) of the LS1 160 thermo was to keep the heads cool to stop pinging. If you're car doesn't have this issue then the t-stat will show no hp gain to you. Second reason was with A4 cars your trans cooler runs through the radiator (even with an aftermarket add-on) so you *could* help keep you tranny temps down a little, assuming you programed the fans correctly. On a M6 car, spend your money else where.
I've had 2 LS1 cars, one A4 w/ 60K+ miles and one M6 w/ 27K miles (current). Both had 160 t-stats installed. The A4 was run hard, the M6 is "babied". Used Mobile 1 in both. Neither had any kind of sludge build up period.
Old 09-19-2006, 08:39 PM
Tech Resident
ChocoTaco369's Avatar
+1 to stock t-stat and fan reprogramming.
Old 09-24-2006, 06:20 PM
LT1-DAN's Avatar
i put a 160 hypertech in my lt1 and noticed no difference but i also do not have a tune.
