Angry help me get rid of abs and air bag lights! PleASE!!(*^*
I have an abs inop light on my 02 ws6 m6. And yes I already checked the third brake light. I was hoping for a pic of where I can find the abs wheel sensors on all the wheels. I was hoping to clean them or see if they connected. Any other ideas?
As for my air bag light...the sensor needs to be reconnected, but i dont know where to find it...anyone have a pic or info on how to reconnect it? I dont want the bags to pop out...
THANKS!!
THANKS!!
and thanks for the repiles guys. I will be checking the wheel snesors and the one at the rear end but i dont think i have one there seeing as i am 02... but if its not the sensors what else could it be?
as for air bag light...no one knows where it is located? Thanks!
Well i have a 3 channel. All the clips were connected and clean. I still have abs light. I did look at engine fuse box and I noticed im missing that big fuse for ABS BATT-1 I have the one for ABS BATT -2 ....could that be it?
And still waiting for a for sure answer to my airbag problem. I know i can unplug light...but how do i get to it? And how do i know which one it is. THANKS!
Check the wheel sensors for moisture and dirt, etc. also make sure you dont have air in the lines or low on brake fluid in the resevoir.
The Airbag light is weird, check the fuse, and im wondering if the car has been in an accident cause thats the number one indicator of a previous collision(light). If not I believe you have to go either GM dealership and have them turn it off
Or try reseting the computer by turning the ign to on pulling the PCM BAT and PCM IGN fuses wait 5-10 mins., turn car off replace fuses. This is what worked for me when my ABS INOP light keeps coming on, and it fixed the problem.
Well I found all the sensors and connections. I checked them all...they are all connected... I cleaned off all the grounds on shock towers... airbag light still on...
I guess I have to disconeect the bulb... How hard is it to get to it? And how do i know which one it will be...
P.S. THE AIRBAG LIGHT BLINKS 6 TIMES THAN STAYS ON. I HEARD 7 IS NORMAL. AND THAT 6 MEANS A CODE THAT INDICATES MY PROBLEM....ANYONE?
"Well I found all the sensors and connections. I checked them all...they are all connected... I cleaned off all the grounds on shock towers... airbag light still on..."
details - where are the connectors?
My air bag light came on last night while doing a 3rd to 4th WOT run, and the car threw a B1000 code too (ECU malfunction).
