Drivers door cover!
Drivers door cover!
Ok, so my door on the drivers side is jacked. The outside covering is coming off of the actual door frame. its like it came unglued or something. I have never seen this before, i could like pretty much peel that whole outside covering off if I wanted to. What do yall suggest?
When my first camaro got totalled one of my doors was like that. The 2 layers actually started to peel away from one another. Your only option is to go to the body shop and see what they say. Maybe get a few opinions so you know the ball park figure of how much its going to cost to fix.
Depends on where it's peeling off. I've had the same prob in the past. If it's on the rear of the door you can do it yourself pretty easily but carefully, with the right opoxy. If its the fwd edge, unless you get really creative, the door will need to come off.
Swing by a body shop to get a qoute, then ask them what kind of adhesive the recommend if you decide to tackle it yourself.
