Every Tech should have these LS Alignment Tools!
AlignIt is a LS Timing Cover & Rear Main Cover Alignment Tool and Seal Installer!
Whether your a Pro or a Do Your Own Repair kind of guy, here is a simple but very effective tool to help you make
easy work of installing your LS1-2-3-6-7-9- LQ4-9- 5.3 Timing and Rear Main cover and seals. Works with all LS based engines!
The AlignIt tool gets the timing & rear main covers centered perfectly with the crank and installs the seal in seconds! Check out the videos.
Having the seal centered accurately with the crank minimizes the chance of seal leakage.
Timing Cover AlignIt Only $29.95
Rear Main AlignIt Only $39.95
Hub simulator only $27.95
Buy more than one of the AlignIt Tools and save!
http://www.saccitycorvette.com/Timin...nmenttool.html
Here is a video that shows how simple it is to use. Tools used in videos are prototypes. The tools we sell are much nicer!:thumbs:
Installation with Oil Pan off.
Here is a Video the shows installation of Rear Main cover and seal with the Oil Pan on.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Same Day Shipping!
__________________
Have a nice weekend!
__________________
