purge help
purge help
I just bought a purge kit for my nitrous works, 100 shot wet kit. Where exactly does it go? Do you put the line from the bottle into the purger and then from the purger to the nitrous sollinoid. The purger has one outlet and two hook-ups on the opposite side. Can someone please help?
Thanks.
Thanks.
youll put the purge right next to the Nitrous noid. You want as short of a distance as possible between the 2. Mine is a HSW kit, and mine Purge noid is mounted on the Nitrous one.
Here is a pic of one hooked up inline with that fitting.
Nick
