Bottle Pressure Question
Just curious how critical it is to be at optimum bottle pressure when spraying, because I had a run with a car the other night that was unexpected and didn't have time heat the bottle up so my pressure was waaaaaaay down. I still won the race easily but my car felt completely different powerwise than it does when i have a chance to get the pressure up in the bottle.
I ran a 150 shot with 720'ish bottle pressure the other night...It dropped .6 seconds off of my 1/4 ET and gained only 5mph(normally I gain 11-12mph)...It was a very dumb move and on a bigger scale it probably could have went so rich that you'd be lifting ringlands or mis-firing...
you guys... haha wow each kit has a specified bottle pressure, if its to low. it will still add the fuel at 58lbs regaurdless so if its to low to much fuel.. to high then not enough fuel or to much n20.. think bout it.
and get it right, dont loose ur motor.
