Leaky Heater Switch
Old 12-07-2008, 09:07 PM
Bryan28's Avatar
Default Leaky Heater Switch
Out for an afternoon romp, bottle is mounted on the hump between the back seats, and a hissing sound, and frost around the heater thermostat switch.. Tightened it to no avail, I assume the internal diaphragm is leaking? Wierd! Only the 4th bottle of nitrous on this system-wich has worked excellent for 3 yrs, car is not a daily driver, nor will it ever be... Any one else come across this occurence?
Bryan
Old 12-08-2008, 08:30 AM
Nick@HSW's Avatar
Can you determine where on the switch its leaking? Did you use any sealer on the threads?
Nick
Old 12-08-2008, 06:27 PM
Bryan28's Avatar
I installed this system about 2 years ago, and yes I did use teflon tape on the threads.. I was told today that it is not an NPT type of fitting, but a 1/2''-20 thread. Should I install it without tape? Seems funny that it never leaked in the last 2 years.. I think its coming from the housing. Any help would be appreciated!
Old 12-08-2008, 10:05 PM
BobDoLe's Avatar
mine leaks too, but it doesn't hiss or anything. very slow leak. it would just get cold and wet. this is after a lot of wear - taking it off, putting it back on, moving it around, etc. not exactly sure where it started leaking from, but removing it and adding more sealant didn't help.
Old 12-08-2008, 11:59 PM
Bryan28's Avatar
Yeah, that's about what mine is doing.. I just took it off, I don't think it ever was adjusted correctly anyway, if I left the heater on for more than 15 minutes, gauge would read 1200 psi, I have been told 950-1000 is optimal for a 125 wet shot single nozzle little guy setup..
Old 12-09-2008, 09:56 AM
Nick@HSW's Avatar
Yes over time they do take a beating. The ones we use are a 1/8NPT so it does require paste on it, unless its a different mfg. But if its leaking internally its time for a new one. Sorry.
Nick
Old 12-09-2008, 07:23 PM
Bryan28's Avatar
No biggie.. As they say- ''That's Racing'' lol...
Old 12-10-2008, 10:15 AM
Nick@HSW's Avatar
Sad truth unfortunately. Its just like any other hobby industry out there. Let me know if you need anything. Thanks.
Nick
