Using relay to send ground?
Old 12-11-2008, 07:27 PM
vetteboyc5's Avatar
Default Using relay to send ground?
Do I have this right? Im a wring noob.
Im wanting a toggle switch to power a relay and send ground to PCM Pin 56. This setup will be hooked in conjunction with my Arm switch
Is this hooked up correctly on the relay once the relay is powered it will ground out the circuit?
Old 12-11-2008, 07:46 PM
myfast70's Avatar
Yes, you have it wired correctly.
Old 12-11-2008, 08:49 PM
Doc
Doc's Avatar
I take it you are using EFI Live's Custom Operating System #5? If so, why not use a DPDT relay?
Old 12-11-2008, 10:00 PM
vetteboyc5's Avatar
Doc, Its anthony Im letting you tune the car.... We talked on the phone last week about this.
yes its EFI live COS 5 as far as the DPDT I have no clue how to do that. This seemed like a easy setup All I have to do is slice right into the Hot wire on pin 86and have that wire power the nitrous relay, and the relay to switch on the tune.
This way I flip the arm switch, the Kit is armed, and instantly grounds pin56 for cos5
What do u think doc?
