Keeping the heads down on a BIG hit
What is everyone doing to prevent pushing water? I have learned quite a bit here and there and want to know all the tricks! I know Tune is a HUGE part but put tuning aside As far as PARTS go what can I get/use to keep these things down on a big hit 400-600. The heads im using are from ET.
Race your car!
The liklyhood of it staying together with 600 worth of nitrous is not very high, you're gonna have to break that up into at least 2, probably 3 stages and the tuneup is CRITICAL to getting that to live, so much so that you're gonna wear the motor 1/2 out before you get there, so plan on freshening it up at least once, probably twice before you get to that power level.
It can be done. atv and I both did it never had any water issues. make sure the heads,deck,gaskets are very clean. they should all be perfect/true. for you best chance copper spray the commetics but we normally don't if they are the first time using them. if its a 4.0 bore use the 4.125 gaskets if its a 3.9 use the 4.60. put quench at .051-.061. tq the bolts down in 3 steps. 25,35,final tq( we use 70 cause thats where the engine builder hones our blocks at. if there new bolts losen them and retighten them 3 times. used bolts 2X. be conservative on timing working you way up not down. good luck LOL
Internet Mechanic
Agreed, the more head studs the better, Ford 5.0's proved that. But when you solve one weak link, then the weakest one left will show up, Typically a piston. Like JL said tune up is critical and talking to the guys who have kept these high n2o shot motors together.
