truck nitrous system on car
Well, i want to know if it's ok to put a truck system over a car and want is the difference between these two system if it's run with the same jettings!
tanks !
-paq-
tanks !
-paq-
the systems will be the same but depending on what truck the kit comes from the jetting may not be correct. The nitrous jets will be but the fuel jet is based on fuel pressure. here is a link that will let you figure out what jets for any size you want. or maybe from the jets you have.
http://www.robietherobot.com/NitrousJetCalculator.htm
Yup as long as its LS based jetted for 58psi fuel pressure, you're good to go. There might be some minor differences such as line length depending on mfg, but nothing major.
Nick
