i need help with a leak
I tried putting my purge kit but it keeps on leaking from the fitting tha goes to the purge solenoid i put teflon paste but it keeps on leaking.I know you shouln't put teflon tape but i am thinking of doing it its already getting me mad i took it off like 3 times and it still leaks.Is there anything else I can put so it can stop leaking?
Is it stripped? I would try thread thread sealant
http://www.neverseezproducts.com/threadsealanats.htm
I use Loctight on all of my fittings, the blue stuff. It seals immediately and works wonders. Teflon paste is great for perfect threads as it's more designed towards non galling then an absolute sealer when you have a nic in the threads. the loctight will fill the nic right up and instantly seal and won't blow out like the paste will and does.
Robert
Robert
