what nitrous kit do you guys suggest?
So here's the low down on the car.
396 LT1 11.7:1 comp
Callies racemaster 3.875 stroke crank
SRP forged pistons/ 14cc dish
Callies Pro I rods/ 5.850 length
Clevite race bearings
Solid roller cam
Intake: .595 Exhaust: .580
Duration @ .050 Intake: 278 Exhaust: 282
Lobe Separation: 112.0
Comp solid roller lifters
Comp pushrods
Comp pro magnum 1.6 rockers/ 7/16 studs
AFR LT4 210's CNC port job w/ 58cc chambers
Ported intake
Canton pan/ melling HV pump
Bored & honed .030" w/ torque plates
Billet main caps
ARP fasteners
Balanced
Decked
QA-1's on all four's
Spohn LCA, Torque arm bar, pan hard bar, and Kenny Brown sub-frame connectors.
built T-56
Mcleod ST
Moser 12 bolt, 4.11's, eaton posi, 33 spline axles
MT ET Streets
I was thinking about dropping a 200 shot on her unless someone would like to suggest otherwise.
396 LT1 11.7:1 comp
Solid roller cam
Comp pushrods
Ported intake
Billet main caps
ARP fasteners
Balanced
Decked
built T-56
Mcleod ST
MT ET Streets
haha i would say that would just about cover the cost. Personally, that is what i would go with then. A direct port gives you the best distribution and gives you the ability to tune with much more accuracy.
its a port matched LT4 intake. and plumbing really isnt a issue with it. i got friends in our hydraulics shop that can whip up some lines in a heartbeat. im going to get her dyno'd as soon as im out of the sand box. thinking she should be around 450 rwhp atleast. then more than likely going to drop a nice 200 shot on her. got a few guys over here with mustangs that are talking some serious smack. so im going to have to show them whats up.
