ET times
Old 01-26-2009, 11:09 AM
Chris'stransam's Avatar
Default ET times
I am building a 408 , i was wondering what kind of times would i be running with a 125 or a 150 shot to a built 408 in a TA m6 . I have been kicking around the FI thing . I just want to run a low11 on street tires , and 10 with slicks
Old 01-26-2009, 11:14 AM
Mike@HSW's Avatar
there are a **** load of variables that will determine what you run. Lots of guys in here with 408s running 9's and some 8's. So to answer your question, its more then possible to run the times you are looking for. All depends on what you put together though. Obviously the entire car as a system is going to determine what you run, not just the motor. Plenty of guys have run easy 10's on cam+spray, so you can def. do it.
