window switch?
That would be one of the first accessories that I recommend. Check out our MicroEDGE controller. Features a built in TPS, dual stage window switch, a/f shut down switch and a bunch of delays and gear lockouts. Let me know if you have any questions. Thanks.
Nick
Nick
It does display a/f as well as a few other readings. The gear lock out features prevents the nitrous from spraying in certain gears. Like say you didn't want to spray anything in 1st gear, 1 stage in 2nd and both stages in 3rd. The microedge can handle all of it for you.
Nick
Nick
Guest
Posts: n/a
We also offer a very nice window switch that will suite your needs aswell.
Single Channel
http://www.nitrousoutlet.com/catalog...roduct_id=2885
Dual Channel
http://www.nitrousoutlet.com/catalog...product_id=964
-Chris
No you will not need a gauge. You can use the display on the microedge. If you want the function of the wideband control, you will need to get something like that has an analog output. However you can still use the lean cut off feature on a stock sensor, if just won't be as accurate as a wideband.
Nick
Nick
Nick
Nick
I am interested here too.....i will be installing a 100 shot NX wet kit in the intake tube pretty soon and i have a bottle heater, purge kit and of course the NX system itself. I do not want to kill my 10 bolt any sooner than it will go (which most likely will be pretty soon when i get my custom cam) so is there a way to get the most of the nitrous without putting the 10 bolt on the chop block?
basically what im asking is, if i spray in first gear out of the hole, would it be any better or worse than spraying say at the beginning of 2nd gear given the rpm drop in the 700r4 from 1st to 2nd?
like they said, it will only shut you down if you go lean, not rich with the narrow band. I bought one of these when I set up my kit, I cant imagine doing it without one of these. I have mine soldered to the stock o2 sensor and havent had any problems. I drilled a hole in the bottom left front corner of my console, routed the wires under my shifter trim, across the passenger underside of the dash and through the grommet in the firewall in the passenger side, and keep the module velcroed to the under side of the lid. trust me, this thing is bad *** and well worth it.
Nick
