stock motor-what rpm do you stop spraying
right now i have my window switch set to go off at 5500. is anyone spraying a stock motor to 6000 or higher. how big a shot? anyone spayed on the dyno with a stock motor to see when it stoping making horsepower?
Race your car!
You pull timing and add fuel for nitrous, that is how you tune for it. An ideal nitrous tune is going to be richer (say 12.5 a/f instead of 13 to 1) and ya need to pull timing, 1 degree for every 25 hp from the n/a tune is a good general rule that's a safe starting point.
mine comes in at 3000 now. i am getting hp tuners on sunday and want to bump it up to 150 or 175. i have the hsw interface and nitrous controller but it only allows for 3 degrees to be pulled without adjsuting the iat if i am not mistaken. i wanted to know how high people are spinning the stock motor. i wouldnt want to burn nitrous if its not helping.
I have a stock 02 Z28 M6 with a dry kit on it spraying 100hp, I have a digital window switch and it comes on at 2600 and goes off at 6000 never been tuned, I have sprayed about 150lbs through it in the last year. I put it on the dyno last month to see what the shot was doing and it made 70 hp more to the wheels, on the graph there was a small spot at about 5000rpm were pcm put in a little knock retard but have never had a problem. It still has the factory lid and it's birth defects on it and the paper filter in it.
