99 z28 nitrous install questions...
Got a nozzle kit just recently and its a wet kit. im running a 85 mm typhoon and throttle body, Since you cant put it before the maf with wet kit where do I stick it?? will i need to tap a hole in my stock bellow? that will look cheesy by the way!!!!! What all goes into deleting the maf??? my tuner uses hp tuners is there a way to delete the maf so i can make an aluminum intake???? Someone please help
