is it ok if i mount my solenoids sideways?
Old 02-15-2009, 04:42 PM
UnZFeat'd's Avatar
Default is it ok if i mount my solenoids sideways?
i just wanted to make sure, im trying searching too. the nitrous solenoid is mouned up and down, but i might have to mount the fuel solenoid sideways. Thanks
Old 02-15-2009, 08:22 PM
jeepers_88's Avatar
Nope, doesn't matter. I have all 3 of mine on their side(n2o, fuel, and purge), everything flowing through them is under pressure anyway, gravity doesn't play a roll here. You can probably find a lot of pictures of others installs that show all different kind of mounting positions
Old 02-16-2009, 07:10 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Agreed, which means you can be SNEAKY!
Old 02-16-2009, 10:16 AM
Nick@HSW's Avatar
Yup, you will be fine mounting them sideways.
Old 02-17-2009, 12:25 AM
Nitro Dave's Nitrous Outlet's Avatar
We have mounted solenoids in all kinds of directions and areas. Some cheap solenoids do not work well with heat or pressure . These two things may be more of a concern.
Dave
Old 02-17-2009, 02:03 PM
UnZFeat'd's Avatar
well i have my fuel solenoid mounted behind my abs module, and my nitrous solenoid is mounted next to my spark plug wires on the passenger side. is that cool?
Old 02-17-2009, 02:43 PM
Strahley's Avatar
I would get them as far away from any heat as I could
Quick Reply: is it ok if i mount my solenoids sideways?
