A/f on nitrous
Old 05-27-2009, 01:14 PM
Austin@HPE's Avatar
Default A/f on nitrous
What are most people running there A/f on bigger shots 150-300 shots just wondering mine is really rich like 10.5-10.7. I know its safer but just want to see how much we might be able to push it. Thanks
Old 05-27-2009, 01:31 PM
Mike@HSW's Avatar
Its not really safer in anyway to be running that rich. The shot range you gave was pretty wide. I would say anywhere between 11.5-12.2
Old 05-27-2009, 02:01 PM
ATVracr's Avatar
Like Mike said Rich is not safe.
There is no magic number every motor will want something a little different.
The 150 shot can be off a good bit and not hurt anything the 300 shot not so much.
Old 05-27-2009, 03:13 PM
Austin@HPE's Avatar
Does leaded 112 affect a/f I run it in nitrous fuel cell and 93 in motor tank. This is on a 200 shot.
Old 05-27-2009, 05:05 PM
bjamick's Avatar
If your running a 300 hit, if it were my motor I wouldn't even have 93 anywhere in the car. Run some C16 in both tanks. You are running a bit rich I would think, rich is not always better . When all that fuel doesn't get burn't and it makes it's way between the rings, thats how you split them up. So lean it up a tad and it will prob pick up quite a bit of power and pick up some mph.
Old 05-27-2009, 06:59 PM
Austin@HPE's Avatar
Ill try to lean it out and ill add some 116 to the tank I drive it back and forth to the track. I have ngk 8s in it also. I'm thinking of stepping the shot up motor was built for 300 hke built it.
Old 05-27-2009, 07:58 PM
bongva's Avatar
so on a 100 shot i can run 12.0 a/f?
Old 05-27-2009, 08:21 PM
Austin@HPE's Avatar
Were just trying to get the tune dialed in because its a progressive but we tune with close to tenth of a second ramp on dyno but on track its no nitrous first and one second after activated.
