How do reverse splits like n20?
i have a 236/234 .615/.598 111-1 LSA cam. it's not installed yet but my other mods are lid, arh lt's, arh y, open plate borla, ls6 intake, p&p tb. its a m6 and i would only want to throw like a 100 shot on it. i would also have all the safety things for N20 along with it. so what do u guys think
you will be just fine spraying that cam. No problem at all. Probably not the "ideal" cam for spray....but in the whole scheme of things, assuming your actually flowing 100 hp worth of juice... you will still see roughly 100 hp gains. If you spray a 200 shot...you will probably see roughly 200 hp. In my experiance of spraying reverse split cams VS traditional split...it is only a hinderance when you approach the maximum limits of your intake or exhaust combos capability...of which cam plays a part. Probably 75% or greater which on your car would likley be in excess of a 300 shot.
spray away.
spray away.
