Stand alone lines?
Stand alone lines?
I received at standalone from Nitrous Outlet and im just a bit confused. I got 4 -6 fittings and 1 -6x6x6 Y fitting to split and feed both stages. Now my noids have a much smaller fitting for the inlet. Am I missing fittings or am I just not getting it?
your solenoids are most likely 1/8" NPT. youll need a male -6 to male 1/8" fitting to join each solenoid.
its part number AT981662
http://www.anplumbing.com/shop/index...Tuff!_Adapters
if not, youre lookin at about 15 bucks.
What does your setup consist of? Are you running a 4 noid direct port? This could be as easy as buying a single 1/8 to -6 fitting.
Typically if your kit is designed for the LSX motors, you will have a -4 feed line from the rail to the fuel solenoid. This is why you will need to get the fitting. It sucks, but this is one of the hidden costs when you start to mix and match kits/setups.
Guest
Posts: n/a
The Dedicateds dont come with the inlet fitting for the solenoid because we dont know what size noid inlet someone has. The person that sold the dedicated should have asked you if you needed that fitting. I'm very sorry about this.
This is the fitting that you will need
http://www.nitrousoutlet.com/catalog...roduct_id=3620
-Chris
-Chris
1st: Thanks chris for your help, a call was placed but after hours. I called next day and found out the info I needed to plumb the system.
2nd: kit is nitrous outlet dual stage plate, with the -4 an inlets, I provided the info that the kit was in fact a nitrous outlet kit and ordered the upgrade for dual noids and was thrown for a loop when I received -6 AN ends to attach to my -4 inlets. Its like buying a new car and goin to drive it only to find that uv been given the wrong key. I assumed, sorry, but its wasnt the end of the world just a few days delay.
3rd: Im not "bitchin" about a $10 fitting, can u honestly say that uv never opened up a new speed part ready to install and are dead ended because of something behond ur control and werent upset? If not, then excuse me for being human. I did call but it was after 6:30, I figured somone on here might have run into the same problem and knew what fittings I needed and I could order them that night. That is what this site is about helping fellow hotrodders like mattl31 did. Then there are some that just post worthless info not relating to the topic.
Thanks to Nitrous Outlet for making excelent products, I understand mishapps happen its part of business. Thanks to everyone who had positive comments and info regarding the thread. Im not here to get in a pissing match over the internet so to others who will make negative comment they will go un-noticed. If this thread becomes more than informative Ill have a Mod lock it and that would be a shame due to teh fact that someone may find the info within valuable at some point.
That is all ima have a beer everyone have a great weekend :Cheers!!:
