Front two cylinders leanest on plate setup?
Old 09-02-2009, 10:42 PM
TS6
TS6's Avatar
Default Front two cylinders leanest on plate setup?
Seems like my front two cylinders (left and right side front, forgive me for not knowing the numbers) look the leanest on the plugs. Kinda weird, I always thought the rear two cylinders would be the leanest, at least on my blower car they are. What should I do? I'm no pro at reading plugs, but they are noticeably whiter thsn the other plugs, which seem to be consistent. This is a 92 MM plate on a FAST/Weiand intake. Running 100 shot right now, 116 in the stand alone, 93 in the tank, etc.
Old 09-02-2009, 11:32 PM
NastyC6's Avatar
what plugs u runiing?
Old 09-03-2009, 08:12 AM
ATVracr's Avatar
Not much you can do with a plate.
Stick a colder plug in those holes or have your injectors flowed and stick the 2 that flow the most in those holes.
