WIll my 04 z06 handle a dry 150 rwhp shot?
Old 09-14-2009, 11:38 PM
ferrari360man's Avatar
Default WIll my 04 z06 handle a dry 150 rwhp shot?
I have a 2004 z06 that is bone stock with the exception of 36lb injectors rated at 43.5, so I know they flow a little more.
I had a 100 shot on it when I had the stock 28.8 injectors, and want to know if I can use the 150 with no harm done. I will be using hsw interface etc to tune fuel and timing.
How much timing should I pull if my car can use this size shot? Also which spark plugs should I run? I currently have the tr6's but ive heard for a shot this size I should go two steps colder from stock?
I will be running 1st gear lockout, window switch from 3000-6000, wot activation switch, and a fpss to help protect me from issues haha.
let me know
Old 09-15-2009, 12:28 AM
SkullV's Avatar
Your stock fuel pump SHOULD handle it but it'll be cutting it close. The injectors will be fine. Pull 6* of timing and run NGK BR7EF plugs.
Old 09-15-2009, 08:16 AM
Hmmm, how much is the stock ls6 z06 fuel pump good for? It is relatively new too. Having it replaced again would be a nightmare.
Old 09-15-2009, 01:52 PM
ysb02's Avatar
Most people running ~550rwp with a blower run a BAP. You won't need to drop the transaxle / tank to install a BAP + racetronix harness.
Old 09-15-2009, 05:05 PM
well I think with stock car and 150 shot id be around 500 rwhp, and not much more... So would I need a BAP for that and 36lb injectors?
Old 09-17-2009, 03:57 PM
ysb02's Avatar
I think you'll be fine ~500rwhp. I'm looking at putting in 60lbers with just a 125 shot. I don't want to go with the 42lbers then put in 60lbers for a blower setup.
