First Time Spraying! Nitro Dave Plate
Well finally got to the track for the first time in 2 years. Installed the nitrous kit this spring. Made a motor pass to see how everything was, went 11.5 @ 119.8. A/f off a bit and didn't hook, only a 1.7 60' so i wasn't to bothered.
My buddy went an 11.3 with his supercharged car so noyzee and i decided to try the new juice kit, got it all setup and waited 5 hours to make another pass!!! Got on it out the hole and it just didn't feel right, super lean, nitrous kit wasn't working. For some reason the window switch wasn't picking up my tach. Thank god we ran into vinny from 860 performance, helped us trouble shoot and figured out that was the issue
Only an hour wait got in line again, track was oiled down twice at this point but i crossed my fingers.. Didn't spray out of the hole, kicked on around the 60' ...
1.56 60' (thanks noyzee!)
10.59 @ 127.5 !!!!!!!!!!!
The plate worked great
Hell of a ride for me. Considering the converter is not good for spray and the car weighed 3600 with me in it. It was fat and low timing, im psyched! Definitely more potential.
NOYZEE edit. this was done on a small drag radial.
8 second mod
timmy, if we get another outing and get that thing dialed in and able to hit out of the hole i see easy 10.3's tire change or gear change and the 150 shot and i see possable 9's
its 100 shot. put up some pics timmy, its all custom very clean install custom hard lines, very very clean and neet. car was fat, we had low timming to be safe and couldnt hit it out of the hole do to a possable cut wire or bad digital box.
we'll see.
car is 3600 pounds and very street friendly. proably one of my best street creations and with timmy as the owner and very hard worker it made it easy and he cleaned it up and did some custom stuff and it clean clean car that goes.
we'll see.
