low pressue with n20outlet plate?
1 Post
I'm going o be building a low pressure 10psi dedicated fuel system for my nitrous system. Will this be a problem with a nitrous outlet plate and lt1 intake manifold?
It shouldn't be, just don't use the jet chart that comes with it. The nitrous jet size will be the same but the fuel jet will be way smaller than the ones used with a high pressure fuel system.
When you buy a regulator get a Holly 12-803. They are the most reliable, fastest responding regulators that you can get and they are only about $25.00! If they are good enough for the Outlaw 10.5 guys and Pro Mods then they are good enough for my slow junk!
Also invest in a good flow gauge, you will need it to dial in your fuel pressure accurately.
How big of a shot are you going to be spraying? If it is more than 200 or so I would HIGHLY recommend going with a direct port. The distribution on LT1 intakes sucks ***, anything over 175-200 with a plate or single/duel nozzle setup and you are playing with fire. Been there, done that...
One more thing, stay away from liquid filled gauges, they are junk....
1 Post
I think you mean I need to run a bigger fuel jet with the lower pressure. I,m stepping up to a 200 shot from a 150. I just dont trust the fuel rail getting sucked dry with that kind of hit. even though I do have a ractronix pump and hotwire kit.
They are just inaccurate. There are lots of causes for it. One big one being temperature.
It may not be as bad on high pressure setups but on a low pressure setup it can cost you a motor. I run the FP on my kits anywhere from 4 3/4 to 5 3/4 psi. If I have it jetted for a 400 shot and one of my gauges are off by 1 or 2 psi then I'm fucked. That is why you need to invest in a good flow gauge. I don't even have a FP gauge on my setup.
Guest
Posts: n/a
