fuel pressure dropping after nitrous
Old 01-27-2010, 12:09 AM
n204u's Avatar
Default fuel pressure dropping after nitrous
I did a stand alone for my nitrous set up, using the blue holley electric pump. I bought a aeromotive regulator hooked everything up set my regulator to 6 PSI and took it for a test drive. After the first spray pressure drops to 4 PSI and doesnt come up. I called Jegs to see why the regulator is dropping pressure and guy said it might be bc the gauge gets hot, its a liquid filled gauge. is this true? what can be the problem?
Old 01-27-2010, 06:46 AM
NXZ28's Avatar
How long is the line from the gauge to the regulator? What brand is the gauge? My autometer sport comp started doing the same thing. I installed a new gauge directly on the regulator with no line and I got an accurate reading.
Old 01-27-2010, 09:48 AM
Nick@HSW's Avatar
Did you do a bypass set up?
Nick
Old 01-27-2010, 11:52 AM
Chris@NitroDaves
Guest
Posts: n/a
Are you dead heading the pump or running a return style system??
Also you might make sure that you tightened the set screw properly...We have seen them come off adjustment due to vibration.
Old 01-31-2010, 11:11 PM
n204u's Avatar
i have a return, and gauge is on the regulator. Its a liquid filled gauge, is that true when they get hot they drop pressure readings
Old 02-01-2010, 12:40 PM
Nick@HSW's Avatar
Its entirely possible but I've never seen it happen. Does the pressure slowly creep up to 6 psi when you first activate the pump? What size return and how far away from the cell is the regulator?
Nick
Old 02-01-2010, 01:00 PM
n204u's Avatar
2-Port Adjustable Fuel Pressure Regulator
-06 AN female inlet and outlet ports
1/8'' NPT gauge port
PART # 027-13201
Fuel Pressure Gauge (Black)
0-15 psi
555-41010
