Best timing retard controller for Speed Density?
Old 05-06-2010, 01:58 PM
ford's Avatar
Default Best timing retard controller for Speed Density?
From what i was reading the Microedge is kind of a pain to set up without a MAF.
Ive read a few things saying the LNC-002 controller is tons easier to setup on a Speed Density tunes. But i kind of want an all in one box. I want a timing controller and window switch that is easily compatible with SD.
Any other suggestions for controllers on a SD setup?
Old 05-06-2010, 03:26 PM
ford's Avatar
Nevermind think ill do the IAT trick and Nitrous outlet progressive controller.
Old 05-07-2010, 03:47 PM
rambodog's Avatar
The timing tuner can pull timing and also serve as a window switch. Its easy to tie into the microedge but the crank sensor plug needs to be accessed for it to work.
Old 05-08-2010, 05:25 PM
Johnv's Avatar
If you tune with EFIlive there are nitrous fuel and spark retard tables available in there custom operating systems, just need to have a pcm pinout earthed when solinoids activate to enable it.
Old 05-09-2010, 01:48 AM
LSxPwrDZ's Avatar
That's pretty kickass.
Old 05-13-2010, 12:49 AM
Nitro Dave's Nitrous Outlet's Avatar
Yep.. Efi live it the shiznet... I use the lingenfelter on alot of applications for timing controll.
Dave
