wanting to add 2 stage dry shot
like the title says im wanting to add nitrous to my ride but i never seen a setup like what im wanting to do. before i get started my car is just an almost full bolt-on LS2 with the A6. i want to do a 2 stage dry ONLY, one shot 125 and the other 50, i plan on using the 50 out of the hole and the 125 when i hit second gear. here is what i think ill need in my setup a boost a pump in with bigger injectors, plate kit, 1 or 2 interface, fuel pressure switch, rpm window switch, wot switch and a nano system.
so my question is since i plan on doing the 2 stage dry plate setup will i need 2 interface, one for each stage, or will i be able to pull it off with 1 interface?
thanks
dicky
thanks
dicky
Its not really worth doing the 50 shot. I agree with Beer99c put it through the maf. But if I was you just get a progressive controller and use that out of the hole and progress the shot. The just use one stage. I use the Nitrous outlet progressive controller with a bigger shot and just progress it where the tires hook then bring it in on a 1.5 sec delay the full 100%
thanks
dicky
thanks
dicky
Nick
