Bought A Dual Stage Wet Kit
Old 06-07-2010, 05:24 PM
d2camaro's Avatar
Exclamation Bought A Dual Stage Wet Kit
Bought this kit and it has no instructions.Tried to find some kinda hose diagrams but having no luck can any body send me a link for a ls1 dual stage wet kit. need a hose route diagram and its a plate system.
Old 06-07-2010, 05:34 PM
hashtagBMW
Speed Density's Avatar
You route the hoses in relation to where you have your noids, its all custom usually. Do you have a p/n for the kit?
Also, if you have other gizmos that go along with the kit youll have to wire them in too, along with the base kit itself. IE: window switch, FPSS, progressive.
Tony.
Old 06-07-2010, 05:37 PM
d2camaro's Avatar
I dont have a p/n for it ,looks like a custom system and i have never installed one befor so im kinda lost
Old 06-07-2010, 06:32 PM
hashtagBMW
Post pictures of it then.
Old 06-07-2010, 07:50 PM
d2camaro's Avatar
Default pics of the system
Old 06-07-2010, 11:25 PM
hashtagBMW
Looks like you do have a two-stage kit, FPSS, and some miscellaneous stuff.
You'll need some sort of activation tool, window switch, TPS switch or button setup to activate it. Your best bet is a digital WS, its the safest and has a built in TPS and RPM activation setup.
In a nutshell:
You'll have one fuel and one nitrous solenoid feeding each nozzle on that ring. You'll wire it all up to an activation controller and then run a main feed from your bottle to the Y- that feeds the noids on the NX side. And you can either get a stand alone fuel system or run your fuel feed of the rail.
Tony.
Old 06-08-2010, 04:21 PM
Chris@NitroDaves
Guest
Posts: n/a
It's not the same kit but i hope this helps.
http://i10.photobucket.com/albums/a1...o/nitrous4.jpg
Also thats not a plate system. It's a dual nozzle kit with a spacer plate. IMO i would get rid of that spacer and put the nozzles in the air bellow.
