timing with the 5177
Old 02-03-2004, 01:03 AM
yourmom's Avatar
Default timing with the 5177
i just ordered the 5177 kit for my 98 z28. I know it says the kit has everything needed to install and run, but i didn't see anything to adjust the timing. can i run the kit the way it is with a 125 shot, or will i have to first purchase a timing controller. if so, what is a cheap one that will work good.
Old 02-03-2004, 07:29 AM
Z'mnypit's Avatar
You shouldnt need any timing at all.... I have the same set up and never messed with my timing, No problems yet!
Old 02-03-2004, 02:35 PM
yourmom's Avatar
thanks for the help.
Old 02-06-2004, 12:00 PM
5 Liter Eater's Avatar
It is a very good idea to install one step colder plugs though. NGK TR6's are a good choice. Gapped @ .030-.035.
Old 02-06-2004, 02:45 PM
GM Muscle's Avatar
Your timing should be okay with a 100-125 shot. Using Sunoco 94 fuel I can run about 28* of timming with no KR. You might have to dump that SLP MAF, mine didn't work well with the nitrous, it gave me a very erratic timming curve and I could never figure out why. You might also have to look into some kind of editing device or a MAF translator, my car went pretty lean on a dry 125 shot.
Old 02-07-2004, 11:41 AM
Apollyon's Avatar
My car is having the timing adjusted to get the best out of the engine when I am not using the nitrous and when I am going to use the nitrous the timing will commputerized to drop and give me the optimum performance from it. I dont know th exact principle of how it will be done but my tuner with the LS1 edit program said my car will get the best of both worlds when I drive it. He has done it before on the other dry nitrous programmed cars.
Old 02-08-2004, 11:43 AM
yourmom's Avatar
thanks man. i'd like to see what you run in the quarter when you get you nos. do you think i can dip into the 12's on street tires and stock clutch with the 5177 kit?
Old 02-08-2004, 11:48 AM
yourmom's Avatar
would the maf translator possibly solve the problem with the slp maf. b/c i got the tsp 85mm airlid so i can't go back to the stock maf. is there a better 85mm maf than the slp? is a maf translator hard to use? would i need an air/fuel ratio gauge?
Old 02-08-2004, 12:28 PM
me_eat_rice's Avatar
yea u can run 12's because i ran 12.87 at 900 psi, and my car was basically stock
Old 02-08-2004, 12:46 PM
GM Muscle's Avatar
I'm really not sure what the problem was with the SLP MAF, it was easier to get rid of it than figure it out. Basicly between 4-6,000 rpm my timing would jump all over the place from 23* to about 27* with no KR at all. I thought it was a programing problem in general and one day a ditched the MAF for the stock unit and I had back a nice smooth timing curve that peaks to where I set it. I believe that Granatelli makes a MAF tuned for dry nitrous use but I don't know much about it. With a MAF translator or any other tuning device the most desirable way to set your A/F ratio is on a wideband but I usualy use my O2's to give me a general idea of where the car is at. I have no experiance with a MAF translator but have heard that there simple to use, I use a Diablo Predator with a custom tune to make adjustments and it's a very simple tool to use which is why I like it. For now I would leave your set up the way it is and install the kit, buy some kind of diagnostic device like Auto Tap or a Predator. Start with a 75 shot and see how things go. If you do purchase a Predator they can send it to you with a custom dry nitrous tune, from my experiance with Diablo there tunes are very accurate to what I have asked for and I only have to make small adjustments.
Old 02-08-2004, 01:47 PM
Apollyon's Avatar
I should be dipping into the high mid 11's because I already run 12.27 in the quartermile with the setup I have now. LS1 edit will help with the MAF you shouldn't need the translator.
Old 02-08-2004, 04:17 PM
yourmom's Avatar
was the 12.87 with your headers and ory installed?
Old 02-10-2004, 06:18 PM
GC99TA's Avatar
Click on the link in my sig. Once at my site, click on the Timing Tuning link. I have a write-up of how to set your timing up to retard only when you spray. It isn't too difficult to do with LS1 Edit and it works great. I run 29* of timing NA and it jumps back to 23 when I spray. Let me know if you have any questions.
Old 02-11-2004, 03:39 AM
Assassin's Avatar
you can run the 5177 on your car the way it is and it'll last forever, once you put some sticky tires you'll need a clutch, and if you miss a gear, you'll need pushrods, but as far as street tires and stock engine, its the BEST way to make horsepower for as inexpensive as possible!
Old 02-12-2004, 03:07 PM
4thGENRETARD's Avatar
N2O and TC are the best bang for the buck any A4 owner can make.
