Controllers
Controllers
I'm a little confused about controllers yet. Finishing up buying nitrous for summer but the main thing im waiting on is the controllers. I am going to have my tuner tune it so that when the system is armed it will pull X amount of timing and I want it setup so it can start spraying at WOT at X number of rpms up until X number before I shift. I was looking into the HSW controllers.. do I need BOTH the microedge & the interface controllers? Or do I just need one? I plan to set it and never touch it again basically.
They don't need to be used together...the MicroEDGE is essentially a window switch with a bunch of built in features such as TPS, a/f shutdown, delays and a bunch of gear lock-outs. The Interface is a fueling and timing controller. If you have other means of fueling and timing then you don't need the controller.
Nick
Nick
Im running just the microedge and its working great for my setup. 150 shot 6 degrees of timing pulled when no2 activates. i use the microedge as a window switch and wot switch, but i spray thur the shifts with a built 4l60.
