Any Nitrous guys running carb setup?
Old 04-21-2011, 07:15 PM
87LSX10's Avatar
Default Any Nitrous guys running carb setup?
I sprayed 150 through a plate on a carbed 5.3 last year. Pulled 10 degrees out from 35 to be safe. I never pulled the plugs to look because I only got two passes in a cracked the bellhousing.Ran great though, no smoke or anything unusual. How much timing are you guys running with what setup?
Old 04-21-2011, 07:31 PM
Red94SS's Avatar
My 6.0 liked 22 degrees with a 200 shot.
Old 04-21-2011, 07:48 PM
Ravenous T\A's Avatar
I will be so im gonna keep an eye on this thread, gonna run a progressive system with my 6010 box
Old 04-24-2011, 09:24 PM
deangoodin's Avatar
ls2,402 cid good bottom end,250 shot on speedtec plate,82 jets,21 degree on timing,5.70s 1/8 3270 lbs,dragradial off the line on no type of delay.
Quick Reply: Any Nitrous guys running carb setup?
