Any big shot sprayers use the timing tuner?
Just curious if anyone out there spraying 250 and up even consider using one. Are most guys just running one tune with the stock PCM?
I bought one but haven't put it in yet, but I won't be spraying more than a 200 for awhile.
8 Sec Tuner
I run a TNT 200 RWHP shot on my Impala SS and i have one tune. You need to retard the timing about 2 deg per 50hp sprayed.
I usually run 34 deg all motor and 28 deg at WOT on the nitrous.
well, i still dont like them Ryan. but if they work for your app, shoot, go for it. my lil ol garage built motor went over 720 RWTQ on stock timing plus 2* and pump gas w/ a relitively safe AFR
BTW, did you find a set of heads? i ran across a set if you havent got them yet.
