Question about wiring a NOS mini progressive
Im installing a mini progressive on my car. I am going to run a WOT switch as well as a Fuel Pressure Safty switch. Can I hook them both up to the progressive through the 2 signal wires and program it to look for both before it activates? Also If I run a delay box or Mallory( To accomidate a trans brake) How is the best way to tie it in as well so that the progressive doesnt activate when it is WOT at the line?
Thanks
Thanks
Guest
Posts: n/a
Thanks
Thanks
Also all you need is a TB Relay.
http://www.nitrousoutlet.com/catalog...6&product=4131
LS1TECH Sponsor
The Launcher can be set-up to kill the system when on the T-Brake but the Mini doesn't have this option. The easiest way to do this is to wire in a 5 pin relay between the TPS and the white/blue wire. See the attached schematic.
Kyle
Kyle
