Stroked LT1 Ignition and Plug help...
Old 03-07-2012, 04:54 PM
Wicked94z28's Avatar
Default Stroked LT1 Ignition and Plug help...
Hey I've never used spray before but bought a Zex kit and planning on throwing a 150 shot on my motor, its a LT1 all forged stroker with -16cc Mahle pistons and port n polished stock heads with a comp cam xfi292, I run mgk irridiums but everyone is changing there plugs to br? Plugs, which plug would you nitrous pros recommend? Also I was referred by a buddy to get the mallory 685 for a ignition , would you say mallory 685 is the way to go? And help.would be appreciated?
Old 03-08-2012, 12:16 AM
No advise?
Old 03-08-2012, 10:22 AM
87silverbullet's Avatar
I would say to use a br6ef plug on a 150 shot and I don't think I would go the mallory 685 box.
Here is a thread on a guy who went that route. I think he changed it up and didn't even use it.
https://ls1tech.com/forums/nitrous-o...k-lt1-pcm.html
Old 03-08-2012, 10:36 AM
Man, call me crazy but I don't see how a standard.copper plug is better then irridium lol and the mallory 685 I'm looking at has a plug and play kit for lt1 cars, but does.the msd have a digital set up where you can male adjustments on the spot like the mallory, also does anyone know if it has a built in 2 step? Thanks!
Old 03-09-2012, 07:48 AM
Nobody said the iridiums were better or worse but from the price standpoint the regular br6ef is king. After watching the guy have problems in the link I sent you, I wouldn't use the mallory 685. With the msd you can add on the timing box of your choice from MSD. We have a SBC that we have a MSD 4 stage retard box and it is capable of 9* per stage.
Old 03-09-2012, 01:22 PM
warriorcustoms's Avatar
An LT1 MSD set up will read like this for dual stage nitrous. MSD 6425 or 6420 ignition box , MSD Multi Stage retard 8970 or 8982 is the other , MSD coil 8226 , MSD wire harness adapter 8876 , & a window switch 8956 or 8969 (digital) If your runnin 2 stages & want MSD youve gotta buy 2. Otherwise get the NOS brand or Trick Performance dual stage window switch. LoL Ask me how I know??? I just bought all of my set up off of here & other sites Yes the mallory is all in one unit. But is it farmed out to china like accel & most others are these days? I used to use accel like crazy till the made in china sticker showed up!!!! Hope this helps
Old 03-10-2012, 08:55 AM
Chopstix's Avatar
the BR6 is the plug I would suggest for motor....use the br7-8 for the 150 shot...also the 685 does work with the LT1 but I would stull suggest the MSD Digital 6 (built in timing retard and 2 step)...this will allow you to use any nitrous controller you want. For ease of install you might want to use Zexs window switch with your ZEX NMU.
Hope this helps
Quick Reply: Stroked LT1 Ignition and Plug help...
