question about race gas
So if I'm running 104 unleaded, in order to get the most out of my 100 shot, could I advcance a degree or two of timing? Or should I leave it where its at? On 91 my timing strap was right where it needed to be on the plug, but when I use 104 will the timing mark move? Or stay the same?
If you have the timing correct for 91 octane, you probably won't see
much improvement anyway.
If he is on a 100 shot he is barely spraying anything!
No point in advancing timing when he can just add nitrous! Motor wants the least amount of timing it can use to still make peak power!
Not saying any ONE way is right or wrong, but just that there are better ways to make more power while keeping your tune-up clean and safe.
