help please, why doesnt it spray?
Ok, got my setup installed, bottle pressure gets perfectly locked at 950-1050, purges out fine, window switch goes green at wot, but no spray. Buddy tested solonoid seperatly and it clicks. All grounds are good. What wud u guess is problem? Im sure its a simple fix and were just missing it. Emailed brandon at n2o outlet havent heard back yet.
^^^ Agree I would just recheck everything even though you have probably already done it a couple of times. It can be a pain but check every little wire all the way down to the plugs.
yeah me and buddy gona give it the once over this morn, just wondered if there was something I was missing someone cud throw off top of their head.
Ha, as usualy is, a simple missed setting in the ole window switch. Cyl typ set to o8 only reading 10% of rpms. Set to 00 read em right, fired off perfect. And yeah im already wondering what the 200 will be like. Already shopping for fuel pumps to support it. Def hooked
No stock ls1 n/a 13.6. Thought thats about average for ls1 fbody stock with a regular joe driving it down the track, hoping to knock a second off at least with the 100shot now working right
LOL yea get better tires and practice more a stock LS1 with skinnies and slicks should do high 12's like a 12.9 or so (thats the fastest that i had read somewhere). With a 100 shot i dont see why you couldn't get low 12's or high 11's good luck and make sure you practice.
