what should my AFR be when i spray
On motor when I am wide open my air fuel is 10.8...when I spray it what is the point of danger that my air fuel shouldn't go up to? I have heard 12.5 is the max is this true? My motor has 60 lb injectors and a 340 aeromotive pump to supply fuel. And also should I run 110 turbo blue cause its a leaded gas or is 93 octane ok?
I sure an't no 'spert, as I have sprayed a total of 4-5 times, I think you are very rich @ 10.8 on moter, I like about 12.8-12.9 on moter and about 11.8 on 125 shot on 93 octane.
JUST MY .02' for what this info worth, Johnny
Bad info all in this thread! This is not any of my business but why would you run a 200 HP shot if you do not even know what a safe A/F is?????
First get your NA tune correct with the A/F ratio Shortdog and Boostit5.3 suggested and then work on your nitrous tune by reading your plugs at the end of the track. Start with a smaller shot say 75 HP or even a 50 HP until you have your nitrous tune safe then work up.
If you do not then as already illustrated by 87silverbullet get the bank account ready for a big withdrawal.
N2
N2
My car has taken a wet 100 shot for almost five years I'm right at 11.9-12.0 on nitrous right at 12.9 on motor I have no fuel upgrades and no tune only thing I did was watched plugs..my car currently has 177k miles and I just pulled bottle of last year to start turbo project..
With you wanting a 200 shot you really need to read more on what some of the guys on here are doing to take 200 shot on stock bottom
