Question for Nitrous
Old 09-24-2013, 02:05 PM
BrntWS6's Avatar
Default Question for Nitrous
I've been toying around just putting a 100-125 shot on my car instead of going FI since I really don't drive it much...~500 miles a year at most. Right now I'm just doing research since I don't know much about it.
My concern is when I did H/C I kissed one of the valves on one piston while rolling the motor over by hand due to a stupid mistake. The valve was replaced but It did leave slight indent on the piston which I cleaned up with a roloc disk to make sure there were no rough edges. I was talking to my friend who is a gear head and he said it may create a "hot-spot" if I spray it. Was just wondering if this would be an issue.
Thanks!!
Old 09-24-2013, 02:49 PM
brandon@nitrousoutlet's Avatar
Thanks!!
I think you should be alright at that horsepower level. This is a stock piston right?
Old 09-24-2013, 02:56 PM
BrntWS6's Avatar
Yes.....stock piston. At what level do you think it may be an issue?
Old 09-24-2013, 03:04 PM
HCI2000SS's Avatar
If it's a very slight nick then i'd have no worries. HCI + 100 shot = lot's of fun
Old 09-24-2013, 03:20 PM
BrntWS6's Avatar
Yeah....it is very slight. After I cleaned up all the build up on the piston it was hard to see.
Old 09-26-2013, 03:58 PM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
Yes!
On a side note, nitrous is fun, affordable and simple. It's there when you need it, and when you want to go fast, simple as that. I don't see that "nick" causing any issues for you, go have some fun and stay safe!
-Garrett
Old 09-26-2013, 04:33 PM
Carter01's Avatar
Thanks!!
That nick will be fine, I did the same thing a few years ago while helping a friend install a cam. We live and learn.....
Quick Reply: Question for Nitrous
