Any nitrious users running a wideband A/F ratio gauge?
Just wondering, alot of people on the other fourm was saying that it isn't necessary especially for a 100-125 shot and its a waste of money..seems like only the people who have turbo or supercharger use a wideband A/F ratio gauge. .
I have a 2002 z06 with ported polished heads, a Big cam, long tube headers and im peiceing up my nitrious kit
(via brandon@nitrousoutlet awesome guy btw) and a few more places..I mean I have the extra money to buy one of these wideband gauges thanks to uncle sam sending me an ok refund check lolol and I figured ill throw in a wideband gauge to my kit just so I can make sure everything is running smooth and if I see that my gauge is showing that my car is running lean, I can cut the car off and send it to the shop so they can see whats wrong with it..besides the gauge looking "cool" isnt a wideband A/f ratio gauge the only way to know if my car is running lean without hooking a laptop to it?
Basically is there anyone here useing an a/f gauge with there nitrious?
Thanks and Im looking for some help as you can see that im a noob with this type of stuff..
Ls1tech & Truck Sponsor
Plugs are the ultimate tuning tool for nitrous, but I also feel a wideband is very important, it may not always be 100% on point but it gives you a pretty good idea of how the car is reacting, and can help identify a lean or fat condition, which is very important.
-Garrett
-Garrett
This is good to know!! I bought my car from a buddy and it had the 2pc MAF kit on it from Nitrous Express. Anyhow he let the car sit under his car port for 5 years and the mice chewed all the wiring up on the nitrous kit.
Needless to say I was just about to order a A/F gauge, I guess it can wait until everything is fixed then.
I have tuned cars at the track and read the plugs and they were perefect and then look at the wideband and is says something stupid like 15:1 A/F ratio. That would make most people who tune their cars with a wideband think they are running lean but the plugs tell the true story. Just use that A/F as a reference.
I'm running a HCI LQ9 motor with a 100 shot, and besides the proper fuel system and plugs, all I run in a nitrous and fuel pressure gauge along with a LNC-2000 for the timing. The a/f is nice but not as nesessary IMO
Do you need one? No, not really. However it is a great tool to have, especially if you have it set up so you can data log it and compare it to your plugs. Now if you aren't doing any tuning and having a tuner put a nice safe tune in the car so you can spray it once in a while the wideband might not mean much to you. I don't think its a very good idea for people to use nitrous in this manner, because if you're injecting it into your car you should know what the bottle pressure needs to be, how the plugs should look, and why things have to be a certain way so you can keep the engine healthy.
I'm currently at 12.7-12.8 on the wideband on roughly 450 worth on nitrous and I'm still quite rich. When I added nitrous jet and leaned it out from 12.0 I got 2 cylinders that showed timing on the straps. I'm pulling another degree down to 10 degrees or maybe 9 and going to lean it out more. Plugs plugs plugs and mph
I have the wide band, fuel pressure ,& nitrous bottle press gauges on a triple pillar pod. Nice to see if not just to ease your mind. (I'm from the more gauges the better school) Not a necessity though. Oh yea I have the microedge nitrous contoller hooked up to the AFR as a safety cutoff.
